Diesel_90 Posted April 25, 2016 Share Posted April 25, 2016 Hi, a friend of mine is having problems with his 1999 disco td5. It will not lock or unlock off the key fobs and to dis arm the immobiliser so it will start you have to turn the key in the drivers door in the correct sequence in order to dis arm the vehicle so you can start it. Can this be turned off in the ECU or bypassed so it will just start off the key? Thanks Quote Link to comment Share on other sites More sharing options...
bear Posted April 27, 2016 Share Posted April 27, 2016 Sounds like the receiver behind the head lining is duff. They can get wet due to leaking sun roofs. Griff Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted May 2, 2016 Author Share Posted May 2, 2016 Thanks. Problem now fixed. Fitted a secondhand ECU with the immobilizer system removed Quote Link to comment Share on other sites More sharing options...
