garrycol Posted April 26, 2016 Share Posted April 26, 2016 I have just about finished the building of my V8 4.6 out of a 4.0 block. I went to bolt on the knock sensors but find the hole in the block is larger than he hole in the sensor. Looking at my engine build book it has a sensor that looks like a pressure or temp sensor that just screws in but my sensors are the different eyelet type that has some sort of bolt that screws into the block to secure the sensor. I am assuming that there is some sort of stud that screws into the block and the sensor is bolted to this. Can someone confirm before I go to find stuff that will fit. Thanks Garry Quote Link to comment Share on other sites More sharing options...
=jon= Posted April 26, 2016 Share Posted April 26, 2016 You probably need something similar to this: https://mcpartsdepot.com/products/stud-knock-sensor-mounting I have similar on my turbo MX5 - you screw the mount like that to the block, then the eyelet type sensor onto that. I would imagine that the RV8 block would prob have different threads etc so you'd need to do your research, or find someone with a lathe to make you something... Other option would be to swap to the original type sensors, as long as the response is the same... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 26, 2016 Share Posted April 26, 2016 Parts book would be a good place to look, links to various sites in the part numbers forum, or just ask Western for a hand Quote Link to comment Share on other sites More sharing options...
garrycol Posted April 27, 2016 Author Share Posted April 27, 2016 Thanks for the information - I will check my local nut and bolt shop to see what studs they have to offer. Cheers garry Quote Link to comment Share on other sites More sharing options...
