Paul64 Posted November 25, 2006 Share Posted November 25, 2006 I have a set of Goodyear Wrangler radials on my LR 6PR tube type. 7.50R 16C 108/106N Steel belt. Max load 60PSI What would be a good road running PSI for around 60mph? Also are these tyres any good? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2006 Share Posted November 25, 2006 Try 28psi front & 35psi rear for lightly loaded normal day to day use, with a heavy or full load up the rear to 48psi Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 25, 2006 Author Share Posted November 25, 2006 Try 28psi front & 35psi rear for lightly loaded normal day to day use, with a heavy or full load up the rear to 48psi Thanks Ralph, Why is it less in the front, as the you are carrying the weight of the engine there? My ignorance is really showing now! Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2006 Share Posted November 25, 2006 LR recommended pressure for the front, so 28psi will carry the front end quite happily & give good steering feel & good braking. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 25, 2006 Author Share Posted November 25, 2006 LR recommended pressure for the front, so 28psi will carry the front end quite happily & give good steering feel & good braking. Got it. Thanks Ralph Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2006 Share Posted November 25, 2006 Got it.Thanks Ralph my 110 runs 28 font & 40 rear [loaded with 400kgs of rally recovery kit] it steers/brakes/handles well & feels good. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 25, 2006 Author Share Posted November 25, 2006 my 110 runs 28 font & 40 rear [loaded with 400kgs of rally recovery kit] it steers/brakes/handles well & feels good. Just been out to check. It wasn't far off, fronts were 26 & 28, rears both 37. The only load in the back is Mr Garspar weighing in at 38kg. Thanks again. Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2006 Share Posted November 25, 2006 Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted November 25, 2006 Share Posted November 25, 2006 give good steering Are you SURE yours is a Land Rover?? Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2006 Share Posted November 25, 2006 Are you SURE yours is a Land Rover?? Yep, quite sure, my steering is very good & not stiff or excesively heavy Quote Link to comment Share on other sites More sharing options...
