browng5 Posted May 2, 2016 Share Posted May 2, 2016 Hi, The rear hub on my Disco 2 is leaking oil onto the brake disc. I have a brand new front hub TAY100060 sitting in the garage. My question is can I fit this onto the rear (using existing ABS sensor) i.e does it have the same internal oil seal assembly as the rear TAY10050?? Graeme Quote Link to comment Share on other sites More sharing options...
bear Posted May 3, 2016 Share Posted May 3, 2016 Hi Graeme, The fornt hub will not fit the rear. However, it's likely to be just the drive shaft O ring. I did mine a few weeks ago. See if you can view the below link on how to do it. Not a difficult job and will cost you about £1.70 http://www.thed2boysclub.co.uk/viewtopic.php?p=421185#p421185 HTH, Griff Quote Link to comment Share on other sites More sharing options...
browng5 Posted May 3, 2016 Author Share Posted May 3, 2016 Thanks Griff, I'll check the o ring first, but want to have a hub there just in case, save stripping it out twice!! Graeme. Quote Link to comment Share on other sites More sharing options...
