reggie Posted May 4, 2016 Share Posted May 4, 2016 Does anybody know where to get the washer from that goes on the end of the turbo return pipe to the block? I have an oil leak in the area and think it could be the washer? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 4, 2016 Share Posted May 4, 2016 What engine? 1 Quote Link to comment Share on other sites More sharing options...
reggie Posted May 4, 2016 Author Share Posted May 4, 2016 Oh yes sorry, that might help ? It's 99 td5 Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 5, 2016 Share Posted May 5, 2016 No seal shown at block end. Have not seen one myself, so can't say what is meant to be used to seal. I assume the hose connects with an inverted flare hydraulic fitting. http://www.allbrit.de/UNI.cfm?PAGE=816537&SPRACHE=EN Quote Link to comment Share on other sites More sharing options...
reggie Posted May 5, 2016 Author Share Posted May 5, 2016 Your right, there doesn't appear to be a gasket/washer at the block end according to that site diagram. I assumed there would be a type of gasket at the flange like the top one where it meets the turbo. So my oil leak must be from somewhere else then as I thought, it does appear to be higher up but a friend was insistent it was from the pipe at the block end. Quote Link to comment Share on other sites More sharing options...
