Ladge Posted May 10, 2016 Share Posted May 10, 2016 I have a Discovery GS 300tdi it’s a 1998 model not the td5, anyway the engine has the EGR fitted which I want to remove, but it also has the air flow meter fitted, so obviously I want that out as well, if I remove both these things, EGR and airflow meter is there anything this might affect or anything else I should be aware of, that might need removing. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted May 10, 2016 Share Posted May 10, 2016 EGR is no problem, fit blanking plates and forget, the air flow meter being fitted would mean you have an EDC engine, you could remove it but not worth it unless it's not working. If you do decide to remove it then you need to swap the injection pump too. The EDC system is very simple and doesn't often give problems, no need to fear it because it's electronic lol Quote Link to comment Share on other sites More sharing options...
Ladge Posted May 10, 2016 Author Share Posted May 10, 2016 EGR is no problem, fit blanking plates and forget, the air flow meter being fitted would mean you have an EDC engine, you could remove it but not worth it unless it's not working. If you do decide to remove it then you need to swap the injection pump too. The EDC system is very simple and doesn't often give problems, no need to fear it because it's electronic lol Thanks for the info appreciate it, Quote Link to comment Share on other sites More sharing options...
Tanuki Posted May 10, 2016 Share Posted May 10, 2016 IMHO if your engine's got the EDC I'd stick with it: electronic control of idle/off-idle and low-throttle fuelling is vastly better than any purely-mechanical clockwork-control can achieve. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted May 10, 2016 Share Posted May 10, 2016 IMHO if your engine's got the EDC I'd stick with it: electronic control of idle/off-idle and low-throttle fuelling is vastly better than any purely-mechanical clockwork-control can achieve. Absolutely, its a good system, why mess with it ? Quote Link to comment Share on other sites More sharing options...
Sheffield Posted May 11, 2016 Share Posted May 11, 2016 The only problem with the EDC system is geting replacement parts. Quote Link to comment Share on other sites More sharing options...
