gemequestrian Posted May 12, 2016 Share Posted May 12, 2016 last weekend my td5 starting leaking/pouring water on closer examinaon one of the core plugs was a little worse for wear so bought new ones and hubby and his mechanic friend replaced put everything back together and now it wont start.it will turn over but not start.fuel pumps working there ate no broken wires etc it was put on the diagnostics machine but nothing came up.we are now both totally stumped as to why it wont start.has anybody had this problem before or any ideas what it could be.all help appreciated thanks. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 12, 2016 Share Posted May 12, 2016 Hi, It is possible that they have caught the fuel cut of switch which is located on the bulkhead and is meant to be activated by the impact of an accident. Jason. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 13, 2016 Share Posted May 13, 2016 Which side of the engine was the work done do you know? Quote Link to comment Share on other sites More sharing options...
