Justus Posted May 16, 2016 Share Posted May 16, 2016 Hi, I'm rebuilding my 88 axles. I need new stub axles, the old are to much pitted to reuse. Now that the whole thing is taken apart, i would like to take the chance to convert to > October 1980 axles. This means that i need: 2* front stub axles FRC3925 at +/- 250 GBP 2* rear stub axles FRC3924 at +/- 35 GPB This is an enormous price difference. So much so that i consider converting rear stub axles to front ones. Differences between front and rear stub axles that i know of: 1- The rear hubs are wet (axle oil is able to travel freely from the casing to the wheel bearings), the front has an oil seal inside of the stub axle. 2- The rear stub axle mount over the axle casing. The front mount against and in the swivel pin housing. There is a "ring" to the stub axle that fits inside. So basically to convert a rear stub axle to a front: -remove the lip on the rear stub axle. -machine and attach a ring which fit inside the swivel pin housing -create room for the oil seal on a lathe (or run wet hubs). Is this correct? Has anyone done this before? Regards, Justus. 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted May 16, 2016 Share Posted May 16, 2016 Why not machine the seal face on your original ones and shrink rings on to get back to original size and a new seal land? The flange on the front stubaxle is somewhat thicker than the rear iirc cheers Steveb Quote Link to comment Share on other sites More sharing options...
Justus Posted May 16, 2016 Author Share Posted May 16, 2016 Hello Steve, I didn't mention the reasons for switching to > 1980 axles (ends). -Uniform bearing size (only one size). Easier to carry spares. -Better oil seals. -Oil catchers. -Thicker stub axle tube. I have just measured the flanges on my old pre 1980 stub axles. Rear stub axle flange: 10 mm. Front stub axle flange: 8 mm. The stub axle tube are the same length. Does anyone know the flange thickness of > 1980 stub axles? Thanks and regards, Justus. Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 16, 2016 Share Posted May 16, 2016 The front stub axles also have bearings to support the shaft near the UJ. It's not a simple job to machine rear stubs for use at the front. You would also need the later hubs as the bearing sizes are different from your current hubs. The old stub axles have replaceable seal lands, so you just need to replace those collars, but the later stubs do not, and require complete replacement when worn or pitted. £££! I did this conversion on a rear axle (I already had the parts). In all honesty, it's probably not worth the cost. You can add the oil catcher rings and machine the drain slots and holes in the existing stubs and back plates if you wish (not a bad idea), but the hub and stub upgrade is not really worth the cost just to change to the later spec bearings. Quote Link to comment Share on other sites More sharing options...
