jad Posted May 18, 2016 Share Posted May 18, 2016 Hello, So I have taken the plunge and bought a 4.6HSE range rover to use the engine to upgrade my tvr 400HC. I am planning to rebuild the engine, get top hat liners fitted, megasquirt it and use arp bolts where podsible. I would like (but not necessarily get) about 300Hp. I would love to supercharge but am thinking normally aspirated will be easier to insure. I am planning on head porting and larger valves. Does anyone know if there are benefits to using either the tvr or lr heads? I believe the tvr heads will have double springs etc but obviously these can be moved to either head. Is it worth increasing the compression ratio? I believe the 4L pistons in the 4.6L will increase it but by how much? Would this increase be negated by composite head gaskets? It's only ever be run on 98 Ron. Increasing the rev range would be nice to do as well. Are there any well known ways of doing this? I have googled but there doesn't seem to be any normal mods for this... yella Terra roller rockers maybe? Solid lifters? I don't want it to be a pig to drive but don't mind reducing low end power/torque a little to get it to sing. Will obviously be getting a new cam etc any recommendations for a lighter car? On a full rebuild is there any other mods/suggestions to improve oiling or anything else? Thanks Jad Quote Link to comment Share on other sites More sharing options...
garrycol Posted May 19, 2016 Share Posted May 19, 2016 I have 4.0 LC pistons in my rebuilt 4.6 - by my calculations you will get somewhere around 9.2:1 comp ratio but I have never found any confirmation of that number. If you do go the 4.0 piston route just be aware that the gudgeon pins have a thinner wall than the 4.6 gudgeons (same outside diameter just a thicker wall so stronger). So get your 4.6 piston gudgeons pressed out and pressed into your 4.0 pistons. Garry Quote Link to comment Share on other sites More sharing options...
jad Posted May 19, 2016 Author Share Posted May 19, 2016 Thanks Garry, that's some useful information. Quote Link to comment Share on other sites More sharing options...
