reb78 Posted June 1, 2016 Share Posted June 1, 2016 My wiper motor on the 110 intermittently graunches, squeaks, squeals etc then it will go through months of silent operation. I do think its trying to tell me something though! Is there anything serviceable/greasable in there or is it a replacement job? If the latter is this genuine only or are there other suppliers of a decent part? Quote Link to comment Share on other sites More sharing options...
western Posted June 1, 2016 Share Posted June 1, 2016 remove it & drive cable, pop the gearbox cover off & clean the old grease out, examine for wear/damage, if all good regrease & refit. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 1, 2016 Author Share Posted June 1, 2016 Will I need to remove the top of the dash to pull the drive cable? Quote Link to comment Share on other sites More sharing options...
western Posted June 1, 2016 Share Posted June 1, 2016 Nope, wiper blades & arms off, so the spindles can rotate fully as the drive cable is pulled out. bottom left corner & grab handle off, disconnect wiper motor electrics & the earth wire & retaining strap, undo the drive tube nut on motor, get some old gloves or rags then remove motor from dash & drive cable will come out of the tubes attached to motor. Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 1, 2016 Share Posted June 1, 2016 I'd highly recommend a rebuild kit I'f you're opening it up... EBay item 370588930713 Quote Link to comment Share on other sites More sharing options...
