sweeney110 Posted June 4, 2016 Share Posted June 4, 2016 Hello all Another problem. I recently fitted a 2006 rear axle into my 1987 110csw. Really just for the rear disc brakes. A coup le of weeks after fitting the bearing seals went so I changed the bearings and seals and thought that was it. I've just discovered that was not the case. The recovery vehicle has just dropped us and the landy off at home as both seals went on the way home from a day out. Bearings started to make a terrible noise and I pulled over to find both brake discs and inner wheels covered in grease and nastiness I'm about to order replacement bearings but there's something else wrong obviously. Anybody any idea what it might be? Thanks Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 4, 2016 Share Posted June 4, 2016 Blocked breather pipe? Damaged seal lands? Quote Link to comment Share on other sites More sharing options...
cackshifter Posted June 5, 2016 Share Posted June 5, 2016 Yeah, Breather has to be the no.1 thing to check, I've had that happen. Or maybe even too much grease too. You might want to consider using the double lipped seal RTC3511 and losing the inner seal so the bearings are oil lubricated if you are having to go to the trouble of rebuilding (see other threads on here). Quote Link to comment Share on other sites More sharing options...
pat_pending Posted June 6, 2016 Share Posted June 6, 2016 Bearings started to make a terrible noise That's not caused by a blocked breather! Reading your post I understand that... You fitted an axle, all was well and then both rear wheel bearings failed along with the seals. You fitted new bearings and seals to both sides, all was well, and now these have failed as well. Is that correct? What exactly "failed" with the bearings? Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2016 Share Posted June 6, 2016 I'd guess the new bearings were not pre greased prior to fitting. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 6, 2016 Share Posted June 6, 2016 Who knows what went wrong.... Bad seal surface, wheel bearing nuts come loose, bearing races not fully set, etc... We can't really magically diagnose what went wrong. as above use the older style hub seals. And remove the half shaft seals to let axle oil into the hubs. Make sure the seal surfaces are good. Make sure the races are fully pressed in. Make sure the bearing nuts are set and locked in properly. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 6, 2016 Share Posted June 6, 2016 What bearing were they? Anything but Timken or similar and it is possible they were just that rubbish they failed that soon. Quote Link to comment Share on other sites More sharing options...
NickHodgson Posted June 7, 2016 Share Posted June 7, 2016 Some pictures of what you changed or even the part numbers would help to think about what has gone wrong. The 2006 axle has a spacer between the bearings - did you refit the spacer? What quality of bearings did you use? Quote Link to comment Share on other sites More sharing options...
