mad_pete Posted June 9, 2016 Share Posted June 9, 2016 My 90 has v8 and zf auto from a Range Rover. Since the inhibitor to stop the car starting in gear was hooked up it seems to have a non starting window after a long trip. If you re start it quickly it is fine, then after say 5 minutes it won't start as though it's in gear and the inhibitor stops it (no starter) and then after a bit longer it is fine again. Possible heat soak from somewhere making something upset? I have mega squirt too. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted June 9, 2016 Share Posted June 9, 2016 I would personally bypass the switch for one or two starts and see that helps..... Carefully! Quote Link to comment Share on other sites More sharing options...
mad_pete Posted June 9, 2016 Author Share Posted June 9, 2016 I could do that but It's pretty intermittent. It seems to need a long run and then some time standing to trigger. Quote Link to comment Share on other sites More sharing options...
