mad_pete Posted June 9, 2016 Share Posted June 9, 2016 My defender is leaning to the drivers side. I did think that was because I put a massive hydraulic fuild tank on the driver side and the high lift but I'm starting to wonder in maybe the springs or shocks are tired. Is there a way to check ? Quote Link to comment Share on other sites More sharing options...
pat_pending Posted June 9, 2016 Share Posted June 9, 2016 The dampers will have no effect on ride height. So, you could either remove the extra weight or try swapping the springs side to side. The fronts are handed but there's not much in it, you want to see if the lean follows the spring. How bad is it? Did it lean before you put the hydraulic tank in? Quote Link to comment Share on other sites More sharing options...
mad_pete Posted June 10, 2016 Author Share Posted June 10, 2016 Not that remember. It seems worse and more to the front recently. I plan to reduce the tank size anyway I think. Quote Link to comment Share on other sites More sharing options...
Josh pickering Posted July 29, 2021 Share Posted July 29, 2021 Hi there, My Land Rover Defender 110 has been leaning on the drivers right hand side, not dramatically but noticeable. I haven’t put anything on the right hand side of my car and it seems to be getting worse every once in a while. Just wondering why this is happening ? Quote Link to comment Share on other sites More sharing options...
