jchasey Posted June 15, 2016 Share Posted June 15, 2016 Hi, Just bought a Defender 90 and the previous owner had made a number of wiring alterations which I am currently investigating... there was also a cubby box installed and having removed it temporarily prior to refitting more securely I discovered the following wiring connections underneath that were not connected...could anyone identify what they are? Many thanks, John Quote Link to comment Share on other sites More sharing options...
cookie64 Posted June 15, 2016 Share Posted June 15, 2016 they look a bit like the connectors for the 300tdi EGR Valve ECU (corect position too) Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted June 15, 2016 Share Posted June 15, 2016 No EGR on a late eighties vehicle. It would have orginally been a 2.5TD Stereo? A better picture of the connectors would make it a lot easier. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 15, 2016 Share Posted June 15, 2016 All Lucas wiring colours are the same from pr-war until and including the 300Tdi. Try looking here http://www.expeditionlandrover.info/Lucaswirecode.htm Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 15, 2016 Share Posted June 15, 2016 Not saying yours is or has had but when I bought mine 1988 90 there was the remains of a split charger system but don't think it was still working so we ripped it out Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 15, 2016 Share Posted June 15, 2016 They are definitely not late 80's ninety plugs those plugs are post 200tdi at the earliest. Having said that it could be a stereo plug. Mike Quote Link to comment Share on other sites More sharing options...
jchasey Posted June 16, 2016 Author Share Posted June 16, 2016 Well the engine has been upgraded to a 300 tdi, so that could be the explanation... Quote Link to comment Share on other sites More sharing options...
cookie64 Posted June 17, 2016 Share Posted June 17, 2016 300 EGR plugs then Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted June 18, 2016 Share Posted June 18, 2016 Another vote for 300 EGR plugs, as it matches what is below the cubby box of my '97 110. EGR has been removed from my vehicle, or perhaps was never fitted as the wiring harness connection for the fuel pump is not there either. Quote Link to comment Share on other sites More sharing options...
