RRC main beam failure
DC_
The main beam on the headlights aren't working. I've got two different possibilities.
1). The relay faulty?
2). ECU ?
It was the search on tinterweb that suggested ECU but, I thought my trusted forum will solve it.
And yes the old cliche, it's for a friend ?
It's a 93/94 200tdi
  • Like 1
Ok, bulbs have been seen working, when you pull lever towards yourself they work. When you push lever away from you they don't stay on constant full beam. (Yes dipped beam is on at this point)
So the problem is lever?
Ok, old lever was in the boot when bought, one on said range on the back. So assuming it's off a donor. Might still be the lever if it wasn't tested.
Think the way forward is a tested lever?
