pep73 Posted July 18, 2016 Share Posted July 18, 2016 Evening lads and lasses as title says my selector has gone mad. Recently whilst shifting from D to R gear box fault would show on my fault reader, putting the selector to D at this point would result in the vehicle being stuck in 3rd gear, however simply knocking her off and restarting from P would reset all and it might not happen again for days. As mentioned earlier it's now doing all sorts. Showing me on the selector it's in R when it's actually in 2nd. Any suggestions greatly appreciated. Quote Link to comment Share on other sites More sharing options...
pep73 Posted July 18, 2016 Author Share Posted July 18, 2016 Apologies- I never put the year up. Its a 2000 2.5 DSE auto. Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 19, 2016 Share Posted July 19, 2016 Take a good look at the XYZ switch. The expected values are in the RAVE, so you can see if that's happening at the pins. 1 Quote Link to comment Share on other sites More sharing options...
pep73 Posted July 19, 2016 Author Share Posted July 19, 2016 Take a good look at the XYZ switch. The expected values are in the RAVE, so you can see if that's happening at the pins. Hi and thanks for the reply. I'm not that well up as I should be. Where would I find the XYZ switch??? Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 20, 2016 Share Posted July 20, 2016 IIRC it's on the side of the gearbox, but check the RAVE for specifics (download link can be found in a sticky in the tech archive). Quote Link to comment Share on other sites More sharing options...
pep73 Posted July 20, 2016 Author Share Posted July 20, 2016 IIRC it's on the side of the gearbox, but check the RAVE for specifics (download link can be found in a sticky in the tech archive). Thanks a million elbekko I've been surfing about and will get to have a look under her today. Quote Link to comment Share on other sites More sharing options...
Dave W Posted July 20, 2016 Share Posted July 20, 2016 The XYZ switch is on the side of the gearbox where the shift cable goes in (nearside). It tells the gearbox ECU which gear you've selected so faults in the switch can lead to some interesting behaviour ! Replacements aren't cheap but it's worth contacting Ashcrofts - when I need a replacement for mine I was fortunate that they had a good second hand one available. They are a bit of a pain to adjust, it takes two people (one underneath to adjust to and one in the cab to move the lever) and a lot of patience to get it just right ! 1 Quote Link to comment Share on other sites More sharing options...
pep73 Posted July 21, 2016 Author Share Posted July 21, 2016 elbekko fair play to your quick response with the correct answer. I fitted the new switch today and we're back on the road! Thanks again. Quote Link to comment Share on other sites More sharing options...
pep73 Posted July 21, 2016 Author Share Posted July 21, 2016 The XYZ switch is on the side of the gearbox where the shift cable goes in (nearside). It tells the gearbox ECU which gear you've selected so faults in the switch can lead to some interesting behaviour ! Replacements aren't cheap but it's worth contacting Ashcrofts - when I need a replacement for mine I was fortunate that they had a good second hand one available. They are a bit of a pain to adjust, it takes two people (one underneath to adjust to and one in the cab to move the lever) and a lot of patience to get it just right ! Thanks dave a nice easy fix this time round. Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 22, 2016 Share Posted July 22, 2016 Good to hear Quote Link to comment Share on other sites More sharing options...
