Paddy Posted July 27, 2016 Share Posted July 27, 2016 Just completed my annual service and found my sedimenter half full of jelly, mostly black. It sinks in diesel so presumably water based and black through bacteria. No real help via google other than it does exist. Anyone any recommendations on a bug killer that's available through motor factors. I will be draining and flushing the tank when the level is lower. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 27, 2016 Share Posted July 27, 2016 I had exactly this' it got through to the engine and then the engine wouldnt start. i had to change the filter several times and bleed through to the injectors. its called diesel bug. i bought two remedies. i'll post pictures in a moment. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 27, 2016 Share Posted July 27, 2016 sorry about the iphone pic http://www.ebay.co.uk/itm/Agricultural-Fuel-Biocide-SW4-250ml-Fuel-Bug-Bacteria-Diesel-Biodiesel-/322191016481?hash=item4b0414c221 http://www.ebay.co.uk/itm/FUEL-SET-CONCENTRATED-FUEL-CONDITIONER-250ML-ALL-OUTBOARD-INBOARDS-/191446762645?hash=item2c931dc495:g:IGgAAOxydlFS1nRt Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 27, 2016 Share Posted July 27, 2016 The biocide will kill any bugs , these will form into a jelly at the bottom of the system. the fuelset will stop them coming back. i drained my tank and flushed it with some sacrificial diesel , then drained again. i then put some bioside in a spray canister and sprayed the inside of the tank, a bit fiddly but doable. i cranked then engine over to get it to come through the priming pump and into a container. once that section was clear i fitted a new filter and cranked again with the injector pipes going to the floor. when i was sure that the lines were clear i refitted the injector pipes, removed the fuel return to the tank and then cranked again. the system was then flushed through. you may need to do this again. i took a sample from the tank and put it in a clear jar with some biocide in. within mins the carp died and you could see it fall to the bottom. it does look like jelly as youve said. once i was certain the system was clear i refilled the tank to about a 1/4 then added the fuel set. run the engine up until it got to temp. i've been putting a dash of fuelset in the tank if i know the truck wont be used for a time. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 27, 2016 Share Posted July 27, 2016 this is what i had. you can clearly see the jelly like bacteria. the samples were from my tank, fresh diesel and from the original source of the contamination, in my case a fuel can. i would suggest to clean out any fuel cans you have too. i swilled some biocide and diesel in mine, then rinsed. Quote Link to comment Share on other sites More sharing options...
Paddy Posted July 27, 2016 Author Share Posted July 27, 2016 Thanks, that’s great info Stephen. Its always good to get someone’s first hand experience of a product. Maybe I’ve caught mine just in time as its only the sedimenter that’s contaminated and not ( visually) got through to the filter. I’ll follow the same procedure with tank washing. I haven’t used any cans so I wonder if the bugs came from my local filling station but it would be hard to pin it down. I may just mention it to them and give them a miss for a while. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 27, 2016 Share Posted July 27, 2016 Jeyes fluid also works. Used be plagued by this, first used bio cide from Wynn's, then jeyes. So far no return. Just add to tank. G. Quote Link to comment Share on other sites More sharing options...
DC_ Posted July 27, 2016 Share Posted July 27, 2016 Very interesting, I've got a sedimenter on mine. Another thing to look at and replace. Question though gazzar, when you say Jeyes fluid, just add to tank. Do you mean pour direct into diesel tank on normal running day to day? Quote Link to comment Share on other sites More sharing options...
Paddy Posted July 27, 2016 Author Share Posted July 27, 2016 Nice tip with the Jeyes. Quote Link to comment Share on other sites More sharing options...
supaimpy Posted July 27, 2016 Share Posted July 27, 2016 Generally thought to be started where condensation is present in steel tanks, at one time it was rife in marine applications such as inland waterways, Fuel Set does work Quote Link to comment Share on other sites More sharing options...
missingsid Posted July 28, 2016 Share Posted July 28, 2016 Natures responce to the devils fuel! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 28, 2016 Share Posted July 28, 2016 Nature's response to diluting the devil's fuel with veg oil! I just put a dribble of jeyes in the tank when I refill. And always fill to the brim. And try burn through a tank a month. Quote Link to comment Share on other sites More sharing options...
