Burbling Posted July 30, 2016 Share Posted July 30, 2016 I am upgrading my 1958 Series 1 to a dual line brake setup, and would appreciate any guidance on the master cylinder to use please. I have 11" drums from a 109 fitted, twin pistons on the front shoes, and have an early Defender brake pedal box with a type 50 servo to fit under the Series 1 bonnet. My research so far has ruled out using the shuttle valve, preferring instead a low fluid sensor on the reservoir and a master cylinder suitable for the 11" drums and the type 50 servo. Hopefully there's a standard build similar to this that I can use the master cylinder from. Thanks in advance for the advice. 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 7, 2016 Share Posted August 7, 2016 Hi an welcome to te forum, If it is a 1958 then it is either a 88 or 109? Either way it is the same dimensions as an 86 under the hood, I tried to fit a Defender servo m/c but I cannot get it under the bonnet! This might be as I have 90 footwells in mine? I have seen one in Classic Land Rover that claimed to have one but can't remember seing photo's so it may be possibleif you cut the wing about? The obvious build is to use Series 3 parts not Defender? Wasn't the late S3 system dual line? Marc. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 7, 2016 Share Posted August 7, 2016 Yes, late S3 was dual circuit. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 7, 2016 Share Posted August 7, 2016 I've the late series setup - can take dimensions, if that helps? Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted August 9, 2016 Share Posted August 9, 2016 I think you can use very late s3 109 master cylinder and use an old fluid sensor cap off a defender? Quote Link to comment Share on other sites More sharing options...
