James NZ Posted August 3, 2016 Share Posted August 3, 2016 Hiya, I've just received a new Lynx for use on our disco 2's, both V8 & TD5. So I thought I'd have a bit of a play on my V8 and read the EMS fault codes. The following photo shows what it read. This is all well and good however it doesn't mean a lot to me. Can any Lynx users shed some light on where I might get additional info on fault code meanings etc. Many thanks, James NZ Quote Link to comment Share on other sites More sharing options...
James NZ Posted August 3, 2016 Author Share Posted August 3, 2016 Hello again, Actually I've come up with some info. Fault 18 seems to indicate a faulty O2 sensor. Fault 34&35 seems to indicate running lean (or it might be running rich, the source of info was a bit ambiguous). Reading these faults and fault 18 together the cure seems to be to replace the faulty O2 sensor and the MAF? Does this sound right? Fault 108. Don't have a flippin clue. Any ideas please? Fault 148. Seems to be related to NAS Passive Immobilization feature. How this was activated in a NZ new car I'm not sure. My car however only opens the drivers door on the first touch of the remote and will open the rest of the doors if the remote button is pushed again. Any ideas on this one? And before you ask, all I did was read the ems fault codes whilst waiting for me dinner to be dished up. So no programming or setting new values. Thanks again, James NZ Quote Link to comment Share on other sites More sharing options...
sierrafery Posted August 5, 2016 Share Posted August 5, 2016 Erase them all and read again after some driving, that 108 can be hystrorical from a moment when the battery died or there was bad contact in the clamps Quote Link to comment Share on other sites More sharing options...
brianc14 Posted August 16, 2016 Share Posted August 16, 2016 Just bought the same bit of kit, read codes and erased OK, Tried some activation checks worked fine, but can't seem to get it to program simple things like curtesy headlights on or off. Britool and Omiga not much help to be honest. I'm pleased we have this forum Quote Link to comment Share on other sites More sharing options...
sierrafery Posted August 17, 2016 Share Posted August 17, 2016 Hi, describe what have you tried and how it failed... did you access the BCU - Programming and you couldn't enable the courtesy headlights? Quote Link to comment Share on other sites More sharing options...
brianc14 Posted August 17, 2016 Share Posted August 17, 2016 Hi, Omitech emailed today and said if the BCU is locked then the Lynx can't make any changes Quote Link to comment Share on other sites More sharing options...
sierrafery Posted August 17, 2016 Share Posted August 17, 2016 I answered about this on the other thread... you decide where but let's talk only in one of them Quote Link to comment Share on other sites More sharing options...
