Tim2809 Posted August 3, 2016 Share Posted August 3, 2016 Has anyone fitted a 90/defender brake pedal into a series 3 with servo fitted and 11" front brakes as standard. Need to fit defender pedal for security reasons Quote Link to comment Share on other sites More sharing options...
Pollywog Posted August 3, 2016 Share Posted August 3, 2016 I have a 90 pedal with the early type 50 servo and master cylinder but I'm running discs up front. The pedal assembly itself bolts straight into position but I had to chop off the pedal and re-weld it on as its slightly longer than the series pedal, also you'll need metric bolts. Quote Link to comment Share on other sites More sharing options...
