Tal Posted August 7, 2016 Share Posted August 7, 2016 I have found this http://www.rimmerbros.co.uk/Item--i-90575573 and it goes here http://www.allbrit.de/UNI.cfm?PAGE=811127&SPRACHE=EN its part number 15 on the diagram. I am mounting an aluminium frame for a flat bed onto my own rebuilt crossmember brackets. The bodywork rests on the crossmembers without fruther fixing (possibly glue) . I need to bolt the aluminium frame to those brackets, so to reduce vibration I want a big rubber washer to fit into the bolt set up. The original buffers fit the bill but at £100 for the four I see no point in using them especially when I would have to modify them anyway. So does anyone have a link to something of similar thickness (about 5mm) or thicker that I could use instead and has an approximately 10mm hole through it. I'm sourcing all the parts I need before I start so there no big worries about changes in design. cheers Tal 1 Quote Link to comment Share on other sites More sharing options...
Tal Posted August 7, 2016 Author Share Posted August 7, 2016 I forgot to add the pad buffer is approx 62 x 78mm (about 2 1/2 by 3 inches) Quote Link to comment Share on other sites More sharing options...
Tal Posted August 9, 2016 Author Share Posted August 9, 2016 ok well I found something that will do the job I and have 2 already. the rubber washer on the rear body mount is a humungous jobby with a big hole in it (very technical) but its perfect and all I need is 4 more...these are they http://www.roverparts.com/Parts/ANR1504. thanks for having a look every one. Quote Link to comment Share on other sites More sharing options...
