200tdi Turbo Oil Pipe Torque
I recently changed the head gasket on our 110 fitted with 200 tdi disco engine. All went well except for two oil leaks. The first is from the oil pipe going to the turbo (bolts in the top of the turbo). There is a weeping leak from it. I've put new washers, same as sump plug ones, on but it still leaks. I'm nervous of tightening the bolt up too far as it is hollow. Does anyone have the torque figure for it and any recommendations for redoing it?
The 2nd oil leak seems to be from the cam cover. It's got new gasket but doesn't seem to be helping. Any other options or thoughts on how to cure it?
Cheers
Ed
 Share
