fearofweapons Posted August 12, 2016 Share Posted August 12, 2016 The dashboard trailer light, green square with a picture of a trailer, does not energise. I understand that it is supposed to come one once per indicator activation without a trailer and every indicator flash with a trailer attached.The bulb is good. What causes this to activate? Is it controlled by the relay? How would I tell if I have the correct relay? It should be noted that the indicators do work as expected otherwise. This is on a 1989 110. Many thanks in advance. Rich T 1 Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted August 12, 2016 Share Posted August 12, 2016 http://forums.lr4x4.com/index.php?showtopic=26752 this has been covered a few times, just trawl the forum. i'm sure i've links before Quote Link to comment Share on other sites More sharing options...
neil110 Posted August 15, 2016 Share Posted August 15, 2016 From memory (sepia tinted) when I first bought a new Land Rover I had a similar thing happen. It was sorted by changing the relay from this http://www.brit-car.co.uk/product.php/95329/0/flasher_relay_standard_discovery_1___defender__94my_ to this. http://www.brit-car.co.uk/product.php/225380/0/flasher_unit_with_trailer_heavy_duty___range_rover_classic___defender Earlier variants used something like this. http://www.brit-car.co.uk/product.php/93242/0/flasher_unit_2_pin_series_111___defender Quote Link to comment Share on other sites More sharing options...
fearofweapons Posted August 18, 2016 Author Share Posted August 18, 2016 Thanks Neil, I'll give the second relay you link to a go I think. Looking at the first I struggle to see how that would work as it only has three pins? regards, Richard Quote Link to comment Share on other sites More sharing options...
western Posted August 18, 2016 Share Posted August 18, 2016 you need PRC8878 http://www.johnrichardssurplus.co.uk/flasher-unit-prc8878.html for a 90/110 with towing kit fitted, Hella do a version in a translucent blue plastic case Quote Link to comment Share on other sites More sharing options...
