HoggyN Posted August 12, 2016 Share Posted August 12, 2016 I'm in the process of getting parts together for a V8 conversion and I need to get a Range Rover flywheel drilled and dowelled to take a Series clutch cover. The bloke who is doing the job for me has asked for drawings. Do any exist? If anybody has the dimensions, I could create the drawing myself. TIA Quote Link to comment Share on other sites More sharing options...
daslandroverman Posted August 13, 2016 Share Posted August 13, 2016 Surely it's just a question of marking the appropriate PCD on the range rover flywheel, centre punch, drill and tap? You should be able to measure the 2.25 flywheel for what you need. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 13, 2016 Share Posted August 13, 2016 Ah, I guess that's the issue with asking someone else to do it vs doing it yourself. I think when I did this a mere 20 odd years ago , I put the clutch cover on the machine table and centred over each hole to find it's position. There are 3 dowels and I forget how many screws. Any machinist worth his salt could do this, but of course it will take a bit more chargeable time ? You could of course make a drawing for him, showing as much info as you can. For instance the screws are 5/16" UNF (IIRC), and you can measure the dowel diameter and note this, along with the number of holes required and their respective depths. If you have the old series flywheel you can check a lot of this yourself. Then note that hole positions must be obtained by measuring the clutch cover. Or maybe someone will pop up with a drawing ready made. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 13, 2016 Share Posted August 13, 2016 Deleted Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 13, 2016 Share Posted August 13, 2016 TBH, once you have the cover located over the 3 dowels you could just 'spot through' the tapped holes. Quote Link to comment Share on other sites More sharing options...
HoggyN Posted August 13, 2016 Author Share Posted August 13, 2016 Thanks for the replies. I do have a Series clutch pressure plate so I should be able to use that to get the dowel PCD and diameter from that and knock up a drawing. I believe that the people that used to sell the adapter kits (Phillips?) also supplied a drawing for the flywheel mods and I was hoping to get a copy to save a bit of time. Quote Link to comment Share on other sites More sharing options...
