joe1 Posted August 13, 2016 Share Posted August 13, 2016 This is relevant to TD5 motors - I obtained a secondhand pas hp pipe (from pump to box), but on inspection the end appears bent - not having seen one of these before it looks a bit odd, so wanted to check with someone who has seen one before. Should it look like this? is the bit on the end an interference fit in the pipe? should I even try to straighten it - it looks like a good fit at the moment, and I've removed the second 'o' ring for clarity. Cheers! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 13, 2016 Share Posted August 13, 2016 It should be straight. You could try to straighten it but if it cracks or breaks it's useless having said that it isn't much good now so you have little to lose. Mike Quote Link to comment Share on other sites More sharing options...
joe1 Posted August 13, 2016 Author Share Posted August 13, 2016 Thanks for swift response Mike, I'll investigate with some carefully applied heat...... Quote Link to comment Share on other sites More sharing options...
