Journey Man Posted August 21, 2016 Share Posted August 21, 2016 Has anyone made a "utility" station wagon? I am considering this as part of a rolling restoration of my 109 SW. If anyone knows of any photos, I'd like to see. Couldn't find any via a Google search. Also, would an 88" side panel with no windows replace the 109" side panels as a direct swap? Thanks Dan Quote Link to comment Share on other sites More sharing options...
Daan Posted August 21, 2016 Share Posted August 21, 2016 Has anyone made a "utility" station wagon? I am considering this as part of a rolling restoration of my 109 SW. If anyone knows of any photos, I'd like to see. Couldn't find any via a Google search. I have seen pictures of this being done, but it was not a factory option. Also, would an 88" side panel with no windows replace the 109" side panels as a direct swap? Yes they are. Thanks Dan Quote Link to comment Share on other sites More sharing options...
western Posted August 21, 2016 Share Posted August 21, 2016 Done the same way as a 110 Utility SW. just replace the upper side panels, or remove the windows, fit a blank panel in the hole or rivet/bolt a sheet of ally over the hole. Quote Link to comment Share on other sites More sharing options...
Journey Man Posted August 21, 2016 Author Share Posted August 21, 2016 Yes they are. Thanks Dan Thanks for that. I'll refurb the glazed panels as well - options! Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 22, 2016 Share Posted August 22, 2016 I have seen a couple of 109s done this way. You could use SIII van sides which would give rear windows but solid sides, or you could find some older SII panels which are solid at the back too. You could also fit 110 rear panels, which would be solid throughout. As much as I dislike the aesthetic of missing the rear windows, they are the weakest point in terms of security, ridiculously easy to push in. Of course, you could always fit guards or the Masai type bonded glass if you use the panels with solid sides but glazed rears. 1 Quote Link to comment Share on other sites More sharing options...
Journey Man Posted August 22, 2016 Author Share Posted August 22, 2016 Hi Snagger Agree regarding the security aspect. I'm planning on using the vehicle for travel and with bikes so would prefer to have them "out of sight" when inside. I like the look of utility station wagons, and detest Masai windows with a passion! Thanks for the details, that's much appreciated. Quote Link to comment Share on other sites More sharing options...
