brianc14 Posted August 22, 2016 Share Posted August 22, 2016 Hi, I suspect these codes are just glitches I have cleared them. 3069 MI Lamp open/load- 3070 Glow plug lamp open / load- 3217 Injector 5 open circuit logged. every thing appears to be working ok, I certainly don't think Injector 5 is off. Can someone explain why the codes don't relate to the P codes you find on the internet, are they special in some way, can they be cross referenced to the P codes? 1 Quote Link to comment Share on other sites More sharing options...
brianc14 Posted August 26, 2016 Author Share Posted August 26, 2016 Anybody Quote Link to comment Share on other sites More sharing options...
sierrafery Posted August 28, 2016 Share Posted August 28, 2016 No glitches at all, those are real codes, the Td5 engine management is not OBD2 compliant so no relation with P codes, for the injector code check the ECU red plug for oil cos if there's oil ingress the output for those warning lamps can be affected too .... dont blame Lynx which is a good tool for the "operator"'s lack of knowledge Quote Link to comment Share on other sites More sharing options...
