Yolandi Posted September 2, 2016 Share Posted September 2, 2016 taking the seats out of my 110 I noticed on the bulkhead at one end soft of a open ended box spot welded on and a fixed strap at the other, is this for stowing a hi-lift? its the only think I can think of so far, in the middle of the bulkhead closer to the floor theres another holder that's soft of a bracket with a large thick o ring that stretches across it (currently holding the fire extinguisher) is there an original intended use for this as well? only one the front seats folds forward so im not sure how you can get the jack in behind them 1 Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted September 2, 2016 Share Posted September 2, 2016 The box end and nylone strap are for the original LR jack body, the rubber ring/plate is for holding the tool kit and jack handle afaik - it was that on mine. The jack base sits behind the seat on the floor. Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 2, 2016 Share Posted September 2, 2016 It wouldn't be for a Hi Lift type jack (farm jack) - it'd be for the basic tools, bottle jack, wheel brace and such that the vehicle would have left the factory with. You can fit a farm jack there, though, as long as it is the right length; I used to do just that with the brackets that came with the jack bolted to the bulkhead. It does have to be mounted as low as possible to avoid interfering with the seat adjustment. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 3, 2016 Share Posted September 3, 2016 I have a 5ft Hi Lift and the best space I've found for it is to take off the base and show it under the seats. It slides in nicely, the base I put under the bracket that supports the corner of the seat. Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 3, 2016 Share Posted September 3, 2016 My Jackall 5' sat on its brackets on the bulkhead without removing ts base. It had to be installed the right way around of course, with the lifting handle lowermost and "jaw" pointing up, and the side with the pins facing forwards. It now resides along the side of the load bay, with the main bulk of it under the second row seat (which is a Defender front seat mounted on the wheel arch top and a special upright inboard) - they do fit there without protruding above the wheel arch top. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted September 4, 2016 Share Posted September 4, 2016 wherever you fit it you need to make sure its substantially secured as in an accident situation they are heavy enough to do a lot of damage ! Quote Link to comment Share on other sites More sharing options...
