lol Posted September 12, 2016 Share Posted September 12, 2016 I've got my MOT due and trying to cure the ABS fault light I've bridged the pins on the 16pin diagnostic plug but the light stays on constant doing a search on the forum seems to indicate I need to remove the ABS relay to get a flash code? Any one have any ideas where the relay is or looks like? Vehicle is a 1997 discovery 300tdi manual Thanks! Quote Link to comment Share on other sites More sharing options...
teabag Posted September 12, 2016 Share Posted September 12, 2016 There's two,both in the passenger footwell, green abs warning + black abs pump, both relays are side by side on the fixed relay bracket... Not the hinged bracket. Quote Link to comment Share on other sites More sharing options...
lol Posted September 12, 2016 Author Share Posted September 12, 2016 Thanks for the reply I've got 4 yellow relays one black bigger relay above that and that's all I can find in the passenger footwell Quote Link to comment Share on other sites More sharing options...
sierrafery Posted September 13, 2016 Share Posted September 13, 2016 In the right bottom pic, C2092/K103 that's what you must remove Quote Link to comment Share on other sites More sharing options...
SPendrey Posted September 14, 2016 Share Posted September 14, 2016 ...and to identify it even easier, it should have two black wires, a black/grey, and a brown/pink wire attached. Quote Link to comment Share on other sites More sharing options...
DiscoveryOneDriver Posted October 11, 2016 Share Posted October 11, 2016 I had ABS light popping up for some time in January this year. I've read somewhere that it could be caused by damp. I sprayed the whole engine bay with the duck oil (Swarfega). It worked. Quote Link to comment Share on other sites More sharing options...
lol Posted October 19, 2016 Author Share Posted October 19, 2016 Cheers for the replys,turned out to be corroded fuse box from too many swimming lessons! Quote Link to comment Share on other sites More sharing options...
