nickwilliams Posted September 16, 2016 Share Posted September 16, 2016 The instructions for checking the camshaft end float on page 75 of the 300 TDI overhaul manual say: 9. Pull camshaft fully forwards and check that end-float is between 0.1 and 1.2 mm. 10. If end-float exceeds 0.2 mm with new thrust plate fitted, camshaft must be replaced. Am I correct in thinking that either the 1.2 in section 9 or the 0.2 in section 10 is a misprint? Which one is correct? Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted September 16, 2016 Author Share Posted September 16, 2016 Sorry, final line in the last post should not be part of the quote but I can't work out how to edit it with the new forum software. Quote Link to comment Share on other sites More sharing options...
