IanT90 Posted September 18, 2016 Share Posted September 18, 2016 Recently replaced my rear discs calipers and pads. Great stops a lot better, however as the vehicle slows to a crawl the brakes squeal. As everything's clean don't suspect brake dust ! Doesn't happen when braking initially only when vehicle's slowed right down and coming to a stop. Any ideas ? Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2016 Share Posted September 18, 2016 pull the pads & apply a smear of copper grease to the rear face where the caliper piston presses on, or there maybe some anti squeal shims you not fitted, did the old parts have the shims if Yes, just swap them into the new calipers. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted September 19, 2016 Author Share Posted September 19, 2016 No shims on the rear although they where on the front. Will try the copper grease tip first thanks Ian Quote Link to comment Share on other sites More sharing options...
