Help please with front Disco1 upgraded to Defender bigger calipers and pads
94Discovery
 Share
Gentilmen i ve searched but i am stuck .
i ve been offered a pair of vented discs and calipers from a defender that use the bigger brake pads and use the solid pins ,i went to order the pads from Paddock spares and could not What to use with what ,is ther any difference with the 110/130 front pads ?does the 90 have the same pads ?
http://www.paddockspares.com/stc8575-brake-pad-retaining-kit-when-fitted-with-vented-discs.html
http://www.paddockspares.com/stc2950m-brake-pads-front-110-130-up-to-1986-split-pin-type-mintex.html
http://www.paddockspares.com/stc2952-brake-pads-front-mintex.html
:wacko::unsure:
Please some guidance
Hi,
This supplier shows dimensions, so you can verify which number will fit:
http://www.ebay.co.uk/itm/LAND-ROVER-DEFENDER-Brake-Pads-Set-Front-BBP0699-Braymann-Quality-Replacement-/331971011850?hash=item4d4b03a50a:g:iegAAOSwzaJX2XZv
In terms of fitting kit, I run this setup and use these springs:
http://www.ebay.co.uk/itm/Land-Rover-Defender-SW-90-MINTEX-Front-Brake-Pads-Accessory-Kit-MBA1176-/262320740111?hash=item3d1388d70f:g:xuQAAOSwu1VW2tMe
The pins are too short when running vented disks, so I have used large split pins instead.
Daan
my 110 has vented front disc & calipers I use these part numbers.
Pads SFP000260 come with the correct pins/anti rattle coil springs
pins are 92mm overall length & 85mm from under head to centre of retaining pin hole, anti rattle coil spring is 55mm long when new.
kit is RTC6799
also see this thread http://forums.lr4x4.com/topic/44441-110-ap-brake-caliper-spring-part/
 Share
