mcc1979ian Posted October 3, 2016 Share Posted October 3, 2016 Evening gents, last night i switched my lights on and got no dip beam but have main. Iv checked fuses and there ok. All earths were cleaned up a few weeks ago for an indicator fault. Any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted October 3, 2016 Share Posted October 3, 2016 is there a black ridged box behind the instrument pack, looks like the photo below might have a blue or white or orange socket. if you have one, just pull the plug out & dip beam lights should work normally, dim dip is no longer required in uk. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted October 3, 2016 Author Share Posted October 3, 2016 Will take a look at the weekend when i get back home but off hand i cant think of seeing one Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted November 15, 2016 Author Share Posted November 15, 2016 Ok so I finally got a weeks holiday so got time for Landrover jobs. Had a look and iv no dim dip module. Mines 1986 so I'm thinking maybe too early. But I do remember when I got it there was a black cable run from o/s blue/white to passenger side blue/red and the other end o the blue/red chopped into the blue/white. I put it all back to normal and it worked fine until I had to change one of the headlight bulbs. Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 16, 2016 Share Posted November 16, 2016 Are you using retrofit halogen lights instead of the original dull sealed beam units? If so, do you have relays fitted? If not, the stalk switch has probably burnt out, the contacts getting too hot and melting the plastic holding them so that the contacts are now recessed. You might be able to repair the switch, but will probably have to replace it. Fitting relays, controlled by the switch but allowing more direct power to the bulbs, will not only protect the switches but will also give brighter headlights. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted November 16, 2016 Author Share Posted November 16, 2016 If I remember rightly iv a spare switch in the garage. I'll get some relays and sort it out and hopefully that cures it. Cheers Quote Link to comment Share on other sites More sharing options...
