Kevm Posted October 5, 2016 Share Posted October 5, 2016 1989, 90" - the alloy plate that the drivers door striker mounts onto has taken a hit sometime, bent it in and cracked it through the angle return/web. It is held by some pop rivets and the bracket support back to the bulkhead, easy to change if I can get another. Can anyone tell me the part number and if it is available? Kev Quote Link to comment Share on other sites More sharing options...
western Posted October 5, 2016 Share Posted October 5, 2016 have a look at pages 855 & 858 of http://www.retroanaconda.com/landrover/parts_books/90/9_body_chassis_p794-923.pdf Quote Link to comment Share on other sites More sharing options...
Kevm Posted October 6, 2016 Author Share Posted October 6, 2016 Thanks, Western but that does not show the panel bit I want, it just shows the B pillar as one continous upright but it is actually made up of several bits rivetted together and it is the thicker latch strengthener plate that I need. Have a look at your own one and you will see what i mean. Maybe i need to look for one from a breakers. Kev Quote Link to comment Share on other sites More sharing options...
western Posted October 6, 2016 Share Posted October 6, 2016 in the 90 parts book page 866 item 12 is the B pillar stiffener http://www.retroanaconda.com/landrover/parts_books/90/9_body_chassis_p794-923.pdf any other bits of B pillar aren't listed as seperate items, only as part of the lower rear tub. Quote Link to comment Share on other sites More sharing options...
Kevm Posted October 6, 2016 Author Share Posted October 6, 2016 That item 12 seems to be a steel stiffener for a truckcab. Looks like the plate I want is as you say part of the tub, so I either try and get one from a scrappie or make one, looks like about 2mm thick but I could do with getting a decent, tougher grade of alloy than plain old soft aluminium. Thanks, Kev Quote Link to comment Share on other sites More sharing options...
