Suffolk Defender Posted October 8, 2016 Share Posted October 8, 2016 Hello all, the defender seems to have developed a new noise. The best way to describe the sound is like a steering lock has been lent against the centre console and is vibrating. It isn't this btw. This noise only occurs when i have driven a little way, so not on immediate start. I have noticed that if i say go to the local tip which is 8 miles, down the local A road so 50 ish all the way, the noise will occur when i come off the A road and stop at the roundabout. Once i have been to the tip and start up again, its not happening. So only after a good session on the road. The noise will go if i ever so slightly rev the engine. And this is at a stand still. Any ideas what i am looking at? Melv Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 8, 2016 Share Posted October 8, 2016 Relationship to engine rpm just gives an idea of the loose article's resonant frequency lining up with the engine vibration. It'd probably happen with the engine cold if you just increase the rpm a tiny bit. Frankly, it could be anything. You need to replicate it while parked to hunt it down. Quote Link to comment Share on other sites More sharing options...
timc1967 Posted October 8, 2016 Share Posted October 8, 2016 Surely you need to find a friend who is willing to sit in the passenger seat and seek out the noise while you are driving along. Appreciate this is easier said than done Quote Link to comment Share on other sites More sharing options...
Suffolk Defender Posted October 19, 2016 Author Share Posted October 19, 2016 On 08/10/2016 at 11:23 AM, Snagger said: Relationship to engine rpm just gives an idea of the loose article's resonant frequency lining up with the engine vibration. It'd probably happen with the engine cold if you just increase the rpm a tiny bit. Frankly, it could be anything. You need to replicate it while parked to hunt it down. this is the issue, this noise ONLY happens when i have given the landy a significant drive, so 50-60 mph for 15 mins. It doesnt happen on small slow runs. Its so hard to work out where its coming from Quote Link to comment Share on other sites More sharing options...
Suffolk Defender Posted October 19, 2016 Author Share Posted October 19, 2016 On 08/10/2016 at 0:21 PM, timc1967 said: Surely you need to find a friend who is willing to sit in the passenger seat and seek out the noise while you are driving along. Appreciate this is easier said than done it doest happen when moving along. its after its been on a significant trip. Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 20, 2016 Share Posted October 20, 2016 5 hours ago, Suffolk Defender said: this is the issue, this noise ONLY happens when i have given the landy a significant drive, so 50-60 mph for 15 mins. It doesnt happen on small slow runs. Its so hard to work out where its coming from If it only happens at idle after braking, and only once hot, then as I said, it is something with a very specific frequency. Cold idle is a little slower, which is why I said that slightl throttle application may replicate it. Otherwise, you need to look at something that is expanding with heat and allowing movement, which is most likely to be to be the exhaust or heater matrix. Quote Link to comment Share on other sites More sharing options...
ericobrave Posted October 20, 2016 Share Posted October 20, 2016 Is the noise there when you are moving or only when stationary after a run ? If the latter then does it go when you depress the clutch ? 1 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted October 20, 2016 Share Posted October 20, 2016 Sounds like your exhaust is rubbing somewhere. Otherwise leave it long enough and you'll eventually spot the offending item disappearing in the rear view mirror.. Quote Link to comment Share on other sites More sharing options...
