big ives 18 Posted October 8, 2016 Share Posted October 8, 2016 SUPERWINCH X9 I have replaced the clutch lever, the internal spring and pin that moves the free spooland the screw on the end of the clutch lever. HOWEVER its operates ok, but if I pull on the clutch lever the whole thing comes out in my hand Looking at the parts catalogue it doesn’t show any other bits that will hold it in place??????????? anybody have an ideal what's wrong Quote Link to post Share on other sites
TSD 102 Posted October 8, 2016 Share Posted October 8, 2016 Not sure I'm understanding your question, but the freespool locking pin is stepped and only the narrow end should fit through the casting? Sounds like the end of the casting under the freespool knob has broken off or been drilled out? Quote Link to post Share on other sites
honitonhobbit 125 Posted October 10, 2016 Share Posted October 10, 2016 Grub screw or what Dave said Quote Link to post Share on other sites
big ives 18 Posted October 11, 2016 Author Share Posted October 11, 2016 lads sorry for the late reply it was a second hand winch I bought and fully serviced and replaced all new parts for the free spool/clutch I am not at home at the minute long way away, however it is possible that the last clown that had the winch drilled the hole bigger but I don't think so, it didn't seem like that when I serviced and rebuilt maybe I didn't pay to much attention everything works at it should and the clutch lever is operating as it should, however it I tug/pull the clutch lever it moves out, will get another look when I get back home in a few weeks..........................................cheers Ivan Quote Link to post Share on other sites
honitonhobbit 125 Posted October 14, 2016 Share Posted October 14, 2016 Should be a ickle teeny weeny washer under the grub scree Quote Link to post Share on other sites
honitonhobbit 125 Posted October 14, 2016 Share Posted October 14, 2016 Also two types of free spool - plastic and alloy. They fit on the same shaft but with a different sizes grub screw - with the same thread size! They have a habit of coming off mind. Just flying off. When I rebuild an X9 I always use thread lock and change the grub screw to a SS cap head I have a lot of X9's - ranging from early to very late and I re-build them for folk. Superb winch, just don't ever power out with plasma Quote Link to post Share on other sites
