Simon_CSK Posted October 14, 2016 Share Posted October 14, 2016 Need to flush out the cooling system on my Range Rover P38 and was wondering what to use to do it. What would you recommend? Quote Link to comment Share on other sites More sharing options...
Davo Posted October 15, 2016 Share Posted October 15, 2016 I've used something over here called "Mukowt", which is just some alkaline stuff in a bottle, so you'll have some equivalent there. You must be careful when using these things as they can eat seals and aluminium radiators, apparently. I'd just back flush with a hose first before putting chemicals in. Can you get to the engine block drains easily? Quote Link to comment Share on other sites More sharing options...
Escape Posted October 18, 2016 Share Posted October 18, 2016 Just water should get most out. The block drain on the LHS is easy to reach, 3/8" square IIRC. Quote Link to comment Share on other sites More sharing options...
