Wave Mountain Posted October 21, 2016 Share Posted October 21, 2016 It came to mind this week that perhaps the process of galvanising my chassis (which is preceded by acid dipping) might not be successful. A little research on Google has reaffirmed my fear that the acid dip bath prior to the galvanising process contains Hydrochloric Acid, but most wax will not be removed by this acid. (any chemists on the forum please say if you think i am wrong here). The best i can hope for is the heat generated by the acid acting on any non-waxed part of the chassis might melt the old wax that exits wishing the chassis. But the bottom line is that if the wax isn't removed then surely the galvanising process will not work, renedering the cost of this useless ?????? ANY THOUGHTS ON THIS ANYONE ? Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 21, 2016 Share Posted October 21, 2016 You could burn it out. I set my chassis on fire (accidentally) welding it (stupidly) after waxoyling it (carefully). The chassis was then filled with fire-extinguisher carp which may or may not assist the anti-rust process. :-) 1 Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted October 21, 2016 Share Posted October 21, 2016 It's worth ringing a few galvanizing places for their views..... Plymouth will probably put you off just due to the price...... mine ended up in Cardiff as they blast and dip on-site..... 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 21, 2016 Share Posted October 21, 2016 To be honest, I wouldn't galvanise a used chassis, just buy a new one. You can see the outside alright, but all manner of horrors can be inside, which even galvanising will struggle to stop. 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 22, 2016 Share Posted October 22, 2016 I'm afraid I'm with Bowie on this one. I've seen the carp on the inside of what looked like a good chassis. Remember they rot inside out. Mo 1 Quote Link to comment Share on other sites More sharing options...
Giles Posted October 22, 2016 Share Posted October 22, 2016 IF (that's a big if) you're happy with the inside, I'd go with Jockland's burn. Doesn't need much, no roaring furnaces, just pile some scrub/sneddings etc around it and toast gently, Gas mark 1, till done 1 Quote Link to comment Share on other sites More sharing options...
Wave Mountain Posted November 1, 2016 Author Share Posted November 1, 2016 I have finally just spoken to Crediton Galvanisers, who only charge £400 + VAT, but they wouldn't do the job because of the wax, agreeing the process wouldn't work. Thank you all for your replies. Apologies for the delay in replying, i am not being pinged when replies come into the forum.........will check my settings ! Are Richards THE only new chassis mob to go for (3 month wait i gather ?) or are Marshland acceptable ? Quote Link to comment Share on other sites More sharing options...
western Posted November 1, 2016 Share Posted November 1, 2016 Marsland are still able to supply, they sell the correct pattern LR defender chassis main rails made of 2 C channels welded top & bottom, whereas Richards use 4 plates welde at the edges. I have a Marsland chassis under my 110, very pleased with it, didn't have any problems bolting parts to it. 1 Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted November 1, 2016 Share Posted November 1, 2016 4 hours ago, Wave Mountain said: Are Richards THE only new chassis mob to go for (3 month wait i gather ?) or are Marshland acceptable ? When I did mine I looked at both Marslands and Richards, I bought at Marsland. Everything just fitted and if you care about such detail its the closest to 'new chassis to original specification' that you can get. 2 Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted November 1, 2016 Share Posted November 1, 2016 So.... crediton wanted 480 quid...... Plus it would have had to be blasted first at the very least...... plus repairs.... So put that against a brand new chassis and it makes having new metal not that expensive! ... If you want a big standard chassis go to marsland. If you want cage mounts or hd rear cross member then go to Richards... 1 Quote Link to comment Share on other sites More sharing options...
