jason101 Posted November 5, 2016 Share Posted November 5, 2016 Hi I've got a p38 , when breaking between 70mph and 50mph getting wheel wobbly , been told probably a steering damper issue , what one should I get to replace it ? and has anyone else had this problem ? thanks Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 5, 2016 Share Posted November 5, 2016 Check bushings and ball joints first. The steering damper will only mask an issue. Quote Link to comment Share on other sites More sharing options...
jason101 Posted November 5, 2016 Author Share Posted November 5, 2016 just had bushes and upper and lower ball joints done for mot . ?? Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 6, 2016 Share Posted November 6, 2016 All of them? Panhard too? Quote Link to comment Share on other sites More sharing options...
smallfry Posted November 6, 2016 Share Posted November 6, 2016 All the bolts done up properly ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 7, 2016 Share Posted November 7, 2016 If it wasn't doing it before the work was done I'd suspect the work done has caused the issue - possibly incorrect setup, preloads etc. Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 7, 2016 Share Posted November 7, 2016 2 minutes ago, FridgeFreezer said: If it wasn't doing it before the work was done I'd suspect the work done has caused the issue - possibly incorrect setup, preloads etc. Not much to preload on a P38, the knuckles are held on by large balljoints, not swivel bearings. Be sure to check those as well. Quote Link to comment Share on other sites More sharing options...
