eds Posted November 8, 2016 Share Posted November 8, 2016 Hi :-) I am just about to change my timing belt for the first time on my Defender 200tdi and am gathering the parts... I can not understand from the tech archive which seals are required as it suggests 2 different ones, as quoted - "timing cover dust seal, crankshaft front oil seal" I have guessed one is ERR4154 but this only accounts for 1 when 2 are shown in the photo. Can some one put me right.. Cheers, Ed Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2016 Share Posted November 8, 2016 the crank oil seal fits the timing case rear section behind the crank timing gear, the dust seal fits in the front cover behind the big vibration damper/pulley assembly, Quote Link to comment Share on other sites More sharing options...
eds Posted November 8, 2016 Author Share Posted November 8, 2016 Thanks Ralph, could you identify the part numbers :-) and do I need both? Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2016 Share Posted November 8, 2016 if they are in the kit change both, parts numbers are Front cover dust seal ETC4154 http://www.brit-car.co.uk/product.php/85599/1119/timing_cover_dust_seal_2_5d_200tdi item 11 in http://www.albrit.de/UNI.cfm?PAGE=747969&SPRACHE=EN Crankshaft front oil seal is ETC5065 http://www.brit-car.co.uk/product.php/425988/0/oil_seal_crankshaft_front item 4 in the above link -- Click on + to read the part numbers. Camshaft oil seal is ETC5064 http://www.brit-car.co.uk/product.php/415854/0/camshaft_oil_seal_2_5d_td_200tdi item 3 in the above link. Brit-car website links used as they show a measure next to seals so should give you a good idea of seal size for the right locations. Quote Link to comment Share on other sites More sharing options...
eds Posted November 8, 2016 Author Share Posted November 8, 2016 Always thank you Ralph :-) 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 8, 2016 Share Posted November 8, 2016 your welcome Quote Link to comment Share on other sites More sharing options...
