Tobias Press Posted November 30, 2016 Share Posted November 30, 2016 Hi I have been looking at putting some larger tires on my 94 defender 300tdi. i am currently running the standard steel wheels and tires. I dont want to fiddle with the suspension. i just want to fill the arches out a bit with some nicer, chunkier tires. i will be mainly using it for road use with some light off road stuff. i have a set of boost alloys which i believe to have 235/85/16 on. these are band new with very few miles on them. will these fit the standard steel wheels? sorry if this subject has been asked before. Thanks Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 1, 2016 Share Posted December 1, 2016 I think they're a bit wide for the steel wheels if they're 5", but I suspect they'd be 5.5" and may be just about acceptable. 7.50s would be a better choice for the steel wheels, though. Why not just use the alloys? They're the correct width for 235, and can accept 255 without an issue. They'd fit the hubs with no messing about; all you need is the correct nuts. Quote Link to comment Share on other sites More sharing options...
Tobias Press Posted December 1, 2016 Author Share Posted December 1, 2016 yes i have considered fitting the alloys, think i may try it a see what i think. thanks for the info Quote Link to comment Share on other sites More sharing options...
bodumatau Posted December 1, 2016 Share Posted December 1, 2016 fit yes, legally fit.... that depends on the tyre manufacturers specification. each tyre has a specific minimum and maximum rime width size it can fit on. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted December 1, 2016 Share Posted December 1, 2016 BFG say 6.0" rim for a 235/85R16. Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2016 Share Posted December 1, 2016 standard defender steel wheels are 5.5 inches wide. OK for 7.50x16 tyres but not 235 which need a minimum of 6 inch wide wheel. Quote Link to comment Share on other sites More sharing options...
