P38 Paul Posted December 10, 2016 Share Posted December 10, 2016 Hello Peeps , Had a starting / glow plug problem on my P38 diesel so I ordered & received 6 new bearmach glow plugs & fitted them to the truck . The starting problem was even worse so I took them out again & stuck each one across a spare battery to see if they were working ok , They all worked but took there time to reach full glow , I then tool the 4 remaining old glow plugs & did the same & found they came up to full glow in a 1/3 of the time . I don't think there is any other problem with the system , just the glow plugs . So I got a replacement set of Bearmach plugs but found these to be the same as the first set , So my question is , what is the best replacement set or brand that I can buy which will heat up quicker than the Bearmach ones to solve this starting problem ? The old ones have no markings on them so I think they might be the cheap & cheerful type but they still started the truck for over 3 years . Has anyone else had this problem with the Bearmach brand plugs ? Regards , Paul . Quote Link to comment Share on other sites More sharing options...
Tanis8472 Posted December 10, 2016 Share Posted December 10, 2016 I would do a search on eurocarparts.com IIRC the oem plugs are Beru Quote Link to comment Share on other sites More sharing options...
pete3000 Posted December 11, 2016 Share Posted December 11, 2016 (edited) No ideas what ours were when they were replaced, got them from car spares distribution, think ngk or delphi ring a bell. about £28 set did the leakoff tubing at the same time and replaced the rubber tubing to the air plenum, after the 2009/10 cold weather caused cranking and smoke but no start. Pete Edited December 11, 2016 by pete3000 extra info Quote Link to comment Share on other sites More sharing options...
