Bigwood Posted February 21, 2008 Share Posted February 21, 2008 In the proces of sorting out my lack of brakes or part there of. Masham to home with one pipe cut interesting. The pipe is changed but I would like to replace the plastic clips that act as spacers were the steel pipes run paralel to each other. No one seems to understand what these are, any clues were to purchase some from. The bleed niples on the front & rear calipers are just rusty stumps. I manged to bleed the brakes ok but I will need to replace the niples. Were the three fronts the same as the rear ones.Bye the way , the cut pipe was a result of the back plate snaping off and wedging between the flexi pipes. Quote Link to comment Share on other sites More sharing options...
