stuntman Posted March 6, 2008 Share Posted March 6, 2008 Hello again MC'ers Right I'm trying to mate my 200tdi from my J plate disco to a gearbox in another J plate 200tdi disco. Are there any differences with any of the models at all? I know the J plate was a year that some parts need chassi numbers for etc, is the clutch one of them? I'm thinking that possibly a bush in the flywheel maybe different, the engine goes together and when you turn the crank on the bottom pully it tries to move the car when it's in gear. I feel that either the input shaft is longer or the recess in the flywheel isn't deep enough, or the housing on the engine or gearbox isn't 'long enough to close the gap? Anyone else experienced this? Regards Andi Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted March 6, 2008 Share Posted March 6, 2008 Hello again MC'ersRight I'm trying to mate my 200tdi from my J plate disco to a gearbox in another J plate 200tdi disco. Are there any differences with any of the models at all? I know the J plate was a year that some parts need chassi numbers for etc, is the clutch one of them? I'm thinking that possibly a bush in the flywheel maybe different, the engine goes together and when you turn the crank on the bottom pully it tries to move the car when it's in gear. I feel that either the input shaft is longer or the recess in the flywheel isn't deep enough, or the housing on the engine or gearbox isn't 'long enough to close the gap? Anyone else experienced this? Regards Andi Both vehicles will have the same spec gearboxes (LT77) of they are both standard. I'm not really sure what you're actually after here.... personally I'd be a bit worried if the car didn't move when I turned the engine over with it in gear...? What exactly is wrong? Matt Quote Link to comment Share on other sites More sharing options...
Paul2A Posted March 7, 2008 Share Posted March 7, 2008 I'm not sure either, but i did have a thought!, have you had the clutch out?, and if so have you refitted the friction plate the wrong way round, IE fly wheel side out?? Quote Link to comment Share on other sites More sharing options...
