Bigwood Posted May 24, 2008 Share Posted May 24, 2008 Has any one out there got a wiring diagram for a 200 TDI Discovery, secificaly the rear windows. Mine blows its fuse as soon as you turn the ignition on. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted May 25, 2008 Share Posted May 25, 2008 I only have the diagram for the front windows. The diagram for the rear windows should be about the same. ST2 = battery +12V ST5 = ignition switch Quote Link to comment Share on other sites More sharing options...
Bigwood Posted May 25, 2008 Author Share Posted May 25, 2008 I only have the diagram for the front windows. The diagram for the rear windows should be about the same. ST2 = battery +12V ST5 = ignition switch Thanks mate, unfortunatly there is a diference because there is an isolator switch in the centre consul. I will print this off any way for future refrence. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted May 31, 2008 Share Posted May 31, 2008 Maybe this one is more fortunate: Quote Link to comment Share on other sites More sharing options...
