way too deep Posted July 2, 2008 Share Posted July 2, 2008 my 200 tdi has started to leak diesel from the top of the body ,it's actually coming out around the throttle arm..is this repairable in my garage or will it need specialist attention..any info tips greatly recieved .thanks ..robbie Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted July 4, 2008 Share Posted July 4, 2008 my 200 tdi has started to leak diesel from the top of the body ,it's actually coming out around the throttle arm..is this repairable in my garage or will it need specialist attention..any info tips greatly recieved .thanks ..robbie Fuel leaking from the throttle arm is down to wear in the spindle that the arm sits on. The injector pump will have to be stripped to repair (spindle has to come out). In the past I've had the spindle machined to take 2x "o" rings instead of the normal single one. It's a specialist job I'm afraid... Matt Quote Link to comment Share on other sites More sharing options...
way too deep Posted July 4, 2008 Author Share Posted July 4, 2008 ok,thanks mate Quote Link to comment Share on other sites More sharing options...
