Another winch question
steve_d
So you have a nice shiny new 9.5c TDS winch and a second hand 12,000lb (reputedly) Chinese type winch.
Which do you put on the front and which on the rear?
There are various thoughts like....are you more likely to want to pull yourself out the way you came in or potentially get yourself into a worse situation trying to go forward.
At this time I don't have the experience to do contests so will not have that 'need' to keep trying to go forward.
Any thoughts?
Steve
In a non competition scenario, if you can pull yourself through the problem, you can always carry on, rather than having to retreat.
If you have 2 winches, and plan to fit them both, I would put the tds on the front, and the chinese on the back, to be upgraded later maybe...
