Dazzer Posted May 11, 2009 Share Posted May 11, 2009 Hi guys, is there anybody in the chesterfield / mansfield area with a rovacom able to come and reset my disco td5 auto. I keep getting the abs lighting up. had it checked once & reset, also had the mechanical side of the abs checked, all ok. Goes without saying, will pay for the help, it's just a bloody nuisance , is this a common problem with the td5?, and does anybody recommend where to start looking if it's a loose connection. I'm not able to get under & over the vehicle myself due to disability, but if i can point out where to look, that'd be a start. Any help greatly appreciated guys. Quote Link to comment Share on other sites More sharing options...
martinhollings Posted May 12, 2009 Share Posted May 12, 2009 if the light is coming on then the abs system is detecting a problem most common problem is abs sensors or play in wheel bearings try this place he is just off oxton roundabout near southwell http://www.landrovernottingham.co.uk/ Quote Link to comment Share on other sites More sharing options...
