voith Posted June 21, 2009 Share Posted June 21, 2009 hi, has anyone a clue how to split apart the wing mirror on a disco td5 es it has lost its locking and i think i might be able to open it and replace a locking circlip onto the main post, this is guess, but i hope someone can help me save some money thanks voith Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 21, 2009 Share Posted June 21, 2009 http://forums.lr4x4.com/index.php?showtopic=40052 Quote Link to comment Share on other sites More sharing options...
voith Posted June 21, 2009 Author Share Posted June 21, 2009 http://forums.lr4x4.com/index.php?showtopic=40052 thanks Quote Link to comment Share on other sites More sharing options...
voith Posted June 22, 2009 Author Share Posted June 22, 2009 hi all, further to this post, i threw caution to the winds today and decided to attack this problem, first I took the glass out, which as you could expect broke the plastic lugs, though i have seen them for about a tenner on the bay so no problem, unscrewed everything in sight, then found using a torch that my thoughts were correct and that the spring washer had come off the post. after mucking around for a while trying to reconnect it, i decided to take the mirror off the door, turning it upside down i found a screw hidden in the turntable part of the mirror accessed by closing the mirror as far as it would go, after this was out i was able to split the mirror to work on the post washer, using two screwdrivers i pushed it back on compressing the spring at the same time, it was only a case of putting everything back together. so i have turned a 100£ job into a 10£ish so can't complain all the best voith Quote Link to comment Share on other sites More sharing options...
