inchman Posted January 12, 2010 Share Posted January 12, 2010 hi my V8 disco dosent seem to be getting fuel up to the rail. I pulled the plug out of the top of the pump sender unit, there dosent seem to be voltage at the white/purple wire, does anybody know the location of the relay that controls the fuel? cheers Gary Quote Link to comment Share on other sites More sharing options...
cipx2 Posted January 14, 2010 Share Posted January 14, 2010 The fuel pump relay is in the RH footwell under the side panel. But between the pump and the relay there are two more things, more likely to fail before the relay: - the inertia cut off switch - on LH side of the bulkhead in the engine compartment - the spider (the immobilizer ecu) - in the usual place, see the tech archive. Quote Link to comment Share on other sites More sharing options...
haggeruss Posted January 14, 2010 Share Posted January 14, 2010 Hi, i had a similar problem just the other day with mine, turned out to be some bad wiring at the rear above silencer. Quote Link to comment Share on other sites More sharing options...
